Changing ATF/FILTER O-RING HELP!
I have dropped the pan and bought the filter/atf. I am just having a severe problem trying to get the o-ring/seal out to put the new one in. I was thinking maybe just use the old one. The only thing is, I have messed the old one up pretty bad trying to get it out. I have put soo much force to it also, like bending the screwdriver kinda force no budge.. I really need some help. I need a working car for work...
Thanks Greg Report Post | I |
01 auto 2.2
Re: Changing ATF/FILTER O-RING HELP!
Greg, an o-ring is made of rubber and how on earth did you bend a screwdriver trying to get it out of the housing. The best way is to use a dental pick. If you don't have one take a long needle, a thick one or a thin knitting needle and sharpen the end. Then insert it into the hole and only puncture the o-ring itself. Pull out toward the middle of the hole and then pull down. It should come out.
Its a metal seal with a rubber coating..
