Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-18-2005, 05:41 PM
nos2spec nos2spec is offline
Question injector and timing problem
ok im new to this but been looking for an answer and have yet to find one lets see if any body knows the answer to this one i just bought a 98 gst eclipse and i cant get it to crank it will turn over and all four spark plugs are getting fire and the number 1 and 2 injectors are working but the other two are not i changed the ecu out thinking that this was the problem to an 95 eprom and change the plug wires around i also changed the cam sensor the timing is good and the ecu works also checked the wires there good also the ecu just wont send a signal to them. i know what you are going to say the ecu is shot but if i unplug the cam sensor all the injectors start working and then the number 2 and 3 plugs stop working. OH im getting good fuel presure
Old 08-18-2005, 10:19 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: injectors problems
I would have also suspected a bad injector driver in the ECU I think... The fact that it works when the CAS is unplugged is officially odd. I don't know enough to be able to provide a solution or even the next step. But I have a feeling this is going to be some bizarre wiring issue. A short with the cas wiring perhaps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-19-2005, 08:06 AM
the only thing i can add is that the ecu box wasnt grounded when i first tryed to crank it with the new ecu could this have missed the eprom up
Old 08-19-2005, 04:19 PM
okay i think i have narrowed it down to the timing. the timing is perfect mechanicly but for some reason its not firing on the right cyl when its at top dead center is it possible for the crank sensor to be out of line or bad with out it going completely out. i have already checked and i`ve got the plug wires switched like it says to for the 95 ecu. but it still wont crank getting fuel pressure and spark but only the 1 and 2 injectors are working. also can the cam sensor gear be on backwards it will got both ways. im getting 4.1 volts on the signal wire from both sensors.
Old 08-20-2005, 03:24 PM
Benag Benag is offline
That actually sounds like the problem I'm having now that I've taken mine to a mechanic. Only the first two injectors aren't working so he says. He said the ecu wasn't sending a signal to them. So I bought an ecu from a used car (I didn't have 1200 for a new one..) and it is doing the same thing. Now when I am driving I can tell the injectors are kicking in because it will push as hard as it usually would. It's like it is missing really bad. The mechanic told me to trade that computer in for a different one so I guess I will unless anyone has any suggestions.
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
Old 08-20-2005, 05:09 PM
i think i have solved my problem i wont be sure until i get the new ecu in next week but it has to be somthing with the ecu and the timing because its prefect mechanicly. i pulled the head and checked the crank sensor and the timing and the wiring its all in perfect working order. only thing left is the ecu and i have been told that some of the 95 ecu`s have to be flashed and reprogrammed to match your vin number so the anti-theft and the cam sensor in the newer model doesn`t conflict with the newer model car. at least i hope that is all it is because if isn`t im going to have a lot of new parts up for sale.
Old 03-07-2007, 04:32 PM
james8racin james8racin is offline
Re: injector and timing problem
if you found out what the problem is could you please tell me, i got the same problem. I bought a new ECU and it didnt work either. I also replaced the injector resistor pack to and that wasnt it. I DONT KNOW PLEASE HELP.
Old 03-07-2007, 06:59 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
RULE NUMBER 1... Don't ever bring back old posts unless their yours! Last post in this thread was 08-20-2005..... You will hear many complaints about this. Make a new thread stating your problem, and the you seen this post and you've tried and it still hasn't worked. Don't bring back the dead, just link to it.
This thread will get locked as soon as a mod (which should be me) gets to it.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-08-2007, 07:08 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Is this a new rule that I missed?
I would actually think that bringing back an old post that contains the same problem would be a good thing as opposed to starting 30 different threads about the same problem. Kindof keeps everything consolidated.
I'm not trying to step on toes or anything.....just wondering.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-08-2007, 11:00 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
nope, this has been an understood rule since I've been here. Typically, threads over a week old are left alone, unless the original poster has another issue or updates on the topic.
Even people who are having the same issue are expected to start themselves a new thread. It is however, expected of them to search for their problem in the past threads first.
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
