Old 08-18-2005, 02:15 PM
baylensman baylensman is offline
Question cruise control
the cruise control on my 94 T & C is not workingnow. It was working fine, then went through a period of about one year when it worked intermittently. now it does not work at all. I don't use it or need it much but i like everything to work. i know next to nothing about chryslers i checked the obvious, like fuses and wire connectors under the hood. any suggestion, can it be checked with a code scanner?
Old 08-18-2005, 10:29 PM
Alan Ross Alan Ross is offline
Re: cruise control
By any chance does your horn not always work & does your airbag light come on & off from time to time?? If so you need recall for the clockspring at no charge from dealer. First the cruise goes & the horn will sometimes not work. Next all will become inoperative. It could be many other things but pay attention to the lights on dash to see
Old 08-19-2005, 09:00 AM
Re: Re: cruise control
horn dash lights turn signals everything function perfectly no flickers interior dimmer works. Just cruise is out
Old 08-19-2005, 12:35 PM
Re: Re: Re: cruise control
Does the cruise light illuminate on dash when you turn it on? If so contin ue reading
Do you know what the cruise machanism looks like? It is under the hood. At the throttle body there are two cables , one goes to the accelerator pedal & the other to the cruise module. It looks sort of like a can with a rubber end on it.
It is controlled electrically & by vacuum.
Possibilities include:
Broken or frayed cable from throttle body to the module, bad vacuum line to the module & faulty electrical connection.
And of course, a faulty cruise module
There are other electronics involved & ways to check that later.
Ususally the cruise fails due to the clockspring or mechanically on these.
Old 08-19-2005, 01:33 PM
Re: Re: Re: Re: cruise control
the "dash" light that says cruise does not illuminate. i don't rember if it ever did.
what is a cruise module? if check for obvious broken lines/cable/wires as well as fuses.
