Old 08-18-2005, 02:40 PM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Is it safe......
.....to polish out tamiya clearcoat which was sprayed 10 days ago?
Please note:
The following words are banned on this thread
1) Read
2) The
3) FAQ
Ta
Old 08-18-2005, 02:45 PM
g00eY's Avatar
g00eY g00eY is offline
Re: Is it safe......
i'm sure it is. i usually polish out my clearcoat the next day, or the day after. 10 days sounds like more than enough.
drunken monkey's Avatar
Razor Sharp Twit
use the search function
Old 08-18-2005, 03:51 PM
Re: Re: Is it safe......
Old 08-18-2005, 03:59 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
It probably won't hurt it, but if you can feel that the clear isn't hard under your sanding pad/polishing cloth, you might as well wait.
Old 08-18-2005, 04:26 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Acrylic or TS? I've polished TS in two hours...I've waited two weeks with Acrylic and it still wasnt hard enough.
-Mike
Old 08-18-2005, 04:48 PM
Cheers guys. Mike, it was TS - looks like I'm getting the polishing cloth out!
Old 08-18-2005, 05:44 PM
mickbench's Avatar
mickbench mickbench is offline
I polished out TS in 4 days.. Dried very fast.. And hard.. Automotive paints and clears was even faster.. and even harder..
I think this should be fine.. I've waited 14 days for normal TS paints though and perhaps this is alittle too long..
Old 08-18-2005, 06:19 PM
Razor Sharp Twit
you're using halfords paints aren't you?
do you find that they also seem to lay down a thinner layer of paint compared to the tamiya sprays?
Old 08-18-2005, 07:01 PM
mickbench's Avatar
Halfords paint from the can is OK. I find TS cans to give a smooth as glass finish, whereas with Halfords can look a little orange peel at times. The clear is OK, but I think I prefer TS clear for getting that smooth finish.
And yes, the base Halfords paint I used was thin.. Runs easy as well..
Old 08-18-2005, 10:16 PM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
I've read a couple of things (i think it was zoomzoomMX-5 who said it)
1. If you can 'smell' paint when you open up the closed container it's in, it's too early
2. If you polish out a paint too early, the shine will dull out in a matter of weeks.
Ed-
