Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 08-18-2005, 12:19 PM
bbluehrtromeo bbluehrtromeo is offline
Unhappy 22r-e timing chain problem
Well, I have a '90 pickup with the 22r-e in it. I bought a timing chain set and put everything on exactly the way they're supposed to be where all the marks are lined up and what not. Crankshaft is at 0 with the top sprocket pointing at the 12 o clock position with distributor dial pointing at spark wire #1 on the cap. I even had 3 mechanics that I know come over and help me do it. But the only problem now is that it won't turn over. Now I'm stuck with nothing. I love this little truck and I really would like to keep it and not have to junk it. Help anyone?
Old 08-19-2005, 12:33 AM
KimMG KimMG is offline
AF - Advisor
Re: 22r-e timing chain problem
What do you mean by it won't turnover? Does the motor spin? Did you try turning the motor by hand? Did you adjust the valves?
Old 08-19-2005, 09:42 AM
The motor spins...belts, everything. It sounds as if it WANTS to start when you turn the ignition, but it just won't start. Anyone have a clue?
Old 08-20-2005, 01:36 AM
AF - Advisor
Fuel, spark, air are the things you need. Do you have them?
Old 08-20-2005, 09:26 PM
toyotruck88 toyotruck88 is offline
Hey I did my 22RE Timing Chain Last Summer.... I (after some consultation with a pro) assembled it together I had a problem getting those dimples lined up and didnt lime them up - I just ensured the crankshaft and camshaft didnt move....
Anyway after I Put it together (ready to start up) - I turned the engine over slowly to ensure no interference between the valves and the pistons occured---- Then I started it up
For it to run you need (from about.com)
1. Spark
2. Proper Air Fuel Mixture
3. Compression (I think this would include cam crank timing)
Old 08-20-2005, 09:28 PM
PS Pull out your chilton manual to the diagnostics place.... And oh yeah retrace ur steps --- I think alot of the igintion coil to distributor wiring is disconnected during this timing chain chore ---
Old 08-20-2005, 11:27 PM
Thanks guys for the help. I'm gonna wait until next week or else put the yota to rest by the side of the garage for winter.
Old 08-22-2005, 03:01 PM
el salsero el salsero is offline
Re: Re: 22r-e timing chain problem
I just got through putting my new timing chain and guides in my truck, same year.
When or if you removed the head make sure your fuel injectors are attached and can easily turn. I also installed a new fuel filter while I was at it.
When I started the truck it turned over like a mofo... so... I went to my shelf and pulled down my can of Easy Start, shot a few bursts directly into the intake manifold...It took one hit, started and purred like a kitten.
