Old 08-18-2005, 08:38 AM
cybermoser cybermoser is offline
1990 truck won't idel when cold
I have a friend that has a 1990 Chevy truck with a 4.3L. Lately he has been having problems with it. When he first starts it up it will not idel when it is cold. If he revs the engine and keeps his RPMs up the truck will run, after it warms up it idels just fine.
He has changed his EGR valve, his PCV valve and a few other things.
Does anyone have any ideas?
Old 08-18-2005, 08:47 AM
hazzzmattt hazzzmattt is offline
Re: 1990 truck won't idel when cold
bad iac motor. easy fix
Old 08-18-2005, 08:52 AM
Re: Re: 1990 truck won't idel when cold
What is a iac motor, please define.
Old 08-18-2005, 08:57 AM
sorry, idle air control motor... screws in the front of the throttle body on that engine, has, i believe a four pin square connector and if im not mistaken comes out of the throttle body at about a 90 degree angle.
Old 08-18-2005, 10:31 AM
Is this the Idle air control motor or valve?
Old 08-19-2005, 12:35 PM
steve3320 steve3320 is offline
BEFORE YOU REPLACE THE IAC, MAKE SURE THAT THE LITTLE BUTTERFLY VALVE IN THE AIR INTAKE IS CLOSING WHEN THE ENGINE IS COLD, THIS COULD ALSO BE CASUING THE CONDITION YOU MENTION. i WOULD THINK IF THE IAC WAS BAD, THE IDLE WOULD BE BAD HOT OR COLD. I BELEIVE THIS VALVE IS VACUUM CONTROLLED ON OYUR TRUCK, SO IT COULD JUST BE DISCONNECTED OR LEAKING. hOPE THIS HELPS
Old 08-19-2005, 01:16 PM
rpreston rpreston is offline
Could also be a bad coolant temperture sensor.
[SIZE=3]"How do you feel about Women's rights?" " I like either side of them."[/size] - Groucho Marx
Old 08-19-2005, 01:37 PM
2000CAYukon 2000CAYukon is offline
That is exactly what I was thinking. If you disconnect it and the truck idles cold, then the sensor is bad.
By disconnecting it, the PCM will think the engine is real cold.
//2000CAYukon
