Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-17-2005, 11:42 PM
playurr playurr is offline
1999 5.2 Loss of acceleration power
I have a 1999 Dodge Ram 5.2 4x4. When I get on the freeway and accelerate It feels sluggish and doesnt have the acceleration power it use to have. I changed the air filter, plugs , and sprayed the carb out with cleaner. any other suggestions?
Old 08-19-2005, 12:45 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1999 5.2 Loss of acceleration power
Did you just put larger tires on?
Does the power loss come at higher rpms?
Any throttle irregularities?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-19-2005, 07:39 PM
I did put new tires on, but they are the same size as I had before, but yes they are oversize It is at higher RPM's.
I dont hink theres any throttle irregularities
Old 08-22-2005, 06:46 AM
With the larger tires, your engine is working harder to turn them, and your acceleration will suffer. Your speedo will also be off. Check out this site to do a comparison:
http://www.1010tires.com/TireSizeCalculator.asp
Old 10-13-2005, 10:27 AM
Mr Kojak Mr Kojak is offline
Re: Re: 1999 5.2 Loss of acceleration power
Not sure if this post is active still, but you might want to have a look at your catalytic converter. Often times when it starts to get older, pieces break off and get clogged in the exhaust piping. This will cause you to lose power, and probably not be able to get rpms over a certain amount. Good luck with your issue.
