Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-17-2005, 10:06 PM
bratt bratt is offline
Will a torn motor mount cause my car engine to shake at low idle rpms?
just curious when i have the car is Drive at low idle the car will shake a but if i pop it in Neutral the shake goes away
i have 1 torn motor mount
should i fix the front motor mount or up my idle from 600 to 900
Old 08-18-2005, 07:01 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Will a torn motor mount cause my car engine to shake at low idle rpms?
I recommend fixing broken parts as opposed to changing something else to make the broken part unnoticeable.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-18-2005, 03:18 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
why is your idle so low? try uping it to 900
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 08-18-2005, 09:24 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
You should fix the motor mount if you know it's torn. Just get prothane's they're like $60 for all four.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-19-2005, 02:17 AM
where is the $60 dollar polyurethane mounts at? autozone? only 1 motormount is torn and that is the front one
Old 08-19-2005, 08:33 PM
ez1286's Avatar
http://search.ebay.com/prothane-ecli...fsopZ1QQfsooZ1
If you don't trust ebay just check some dsm sites they're usually not much more
Old 08-19-2005, 11:19 PM
no way! i dont want those polyurethane drag engine mounts
they cause the interior of the car to shake. this car is not a drag car its just a normal car! its not even turbo
i'll stick to stock that is what im trying to get rid of the stupid shaking at idle bugs me
Old 08-27-2005, 06:08 AM
ricebike ricebike is offline
just goto advance auto parts/ autozone then :P
Old 09-03-2005, 04:19 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
My car would shake if it idled at 600 rpms too hahah! Turn that bitch up!
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 10-21-2005, 01:12 PM
laser apexi turbo laser apexi turbo is offline
my laser turbo idles at leik 650 and i got a torn motor mount... it doesnt shake unless its abut to stall out. othoe im replacing it soon i sugjest u do the same
