Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 08-17-2005, 08:50 PM
common_sense common_sense is offline
1991 Trooper reverse gear problem
Hi there:
Could someone be kind enough to help me with the following question?
Everytime or most of the time when I try to put the trooper in reverse, it tends to refuse to enter reverse gear. So what I do is to put it into any other gear and then try the reverse. This usually works. What could be the problem that it doesn't shift smoothly?
Thanks for your help!
Old 09-04-2005, 10:44 PM
JesseJamesMcGuire JesseJamesMcGuire is offline
Re: 1991 Trooper reverse gear problem
I have this problem sometime also,
I belive it is due to.
1. RPM to high ( 8000 is normal)
2. Check throttle return
I can't remember the rest but I have a helm manual with walk throught I could check if you would like.
Old 09-10-2005, 11:41 AM
I definitely would appreciate if you could get me some more info on the problem. Thanks!
Old 09-13-2005, 01:01 AM
okay
I will look up the information and post it for you. I have to find my book because I just moved that is why it has taken me so long to reply.
