Old 08-17-2005, 08:16 PM
Revelation Revelation is offline
stubborn trans plug
hello i got a 95 geo metro 4cyl manual trans
well i bought this car about 3months ago and decided it was time to change the tranny fluid because it has a leak
well much to my surprise/fear the fill plug is rounded out ....should be a 3/8 ratchet but rounded wont grip....the plug is flush with the tranny so i dont see vise grips or a pipe wrench doing much good....so i got an easy out from a friend and well not enuff room to tap it in darn compact cars ....well i really need some advice on how to get this stubborn thing out its rounded out and very tight
Old 08-18-2005, 06:56 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Re: stubborn trans plug
It sounds like a tough project but I think I would start out with my Dremel tool and grind new flats on the inside. I would fit it to some high carbon steel square keystock.Then I would heat carefully around the outside of the plug and then try to remove it.
Good luck!
Craig
Old 08-18-2005, 04:55 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Just take it to a shop and have them weld you a head on it.
