Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-17-2005, 05:40 PM
hiduke89's Avatar
hiduke89 hiduke89 is offline
Send a message via MSN to hiduke89
suspension lift
i have a 97 ext cab ram and am lookin for about a 2inch suspension lift. Any on have any suggestions or ideas on how much it will cost? the cheaper the better.
Old 08-20-2006, 04:22 PM
jackrj jackrj is offline
Re: suspension lift
if all you want is 2" of lift then you should just get a 3"body lift for around 250.00 off of ebay or most 4x4 stores in your area. a 3" lift will allow you to run 33's and i would not go wider than 10.5" in width on the tire. the mud terrains that bf goodrich have are an aggresive looking tread but if you don't get muddy then an all terrain t/a is going to give you more bang for your buck because they will last a lot longer. if you really want the 12" wide tire then you will have to get new rims with 4.5" backspacing to go along with the new tires as well and this will place more stress on your axles...kind of like doing the splits between two chairs, ouch! but again, if you don't off road much then this too is of very little concern. hope this helps.
