Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-17-2005, 05:37 PM
bratt bratt is offline
Angry Help with cold air intake on 92 eclipse gs
i just got a cold air intake for my 92 eclipse gs
i cant figure out how to put my air flow meter on this thing
it just wont work
does any1 know what i do can i cut it apart or what???
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
i got this one
Old 08-17-2005, 05:42 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
i'd say forget about it, i i used to onw a 92 gs a long time ago, i got the same CAI , i kept trying for like a week, and ended up installing it in my uncles chevy s-10, lol, if you wanna do it , i believe you have to buy an adapter, but i'm not sure,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 08-17-2005, 05:44 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
That's not a CAI, I don't care what they say. That is a short ram. You probably won't notice much of a difference with a short ram. What air flow meter thing are you talking about? Pictures would be good. The only thing I can think of that you are talking about is the breather that connects to the top of the valve cover?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-17-2005, 05:57 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Help with cold air intake on 92 eclipse gs
Originally Posted by l_eclipse_l
That's not a CAI, I don't care what they say. That is a short ram. The only thing I can think of that you are talking about is the breather that connects to the top of the valve cover?
What I think he's talking about is the mass air flow sensor (the giant thing on the end of your stock intake that holds the air filter), I think hes asking how to make it work because the pipe that he bought has like a little tiny pipe that comes off of it in like the middle of the pipe and supposidly the MAF sensor is suppose to connect to this. I'm having the same issue help me too.
Old 08-17-2005, 06:13 PM
thats exactly what im talking about
and the problem is i cant fit that sensor in my air filter because its too small and doesnt line up
the 1 hole on the pipe goes to the intake manifold
it would work but i cant get my MAP air flow sensor in there and the check engine light comes on and throws codes
Old 08-17-2005, 07:17 PM
ned032002's Avatar
Re: Re: Help with cold air intake on 92 eclipse gs
I considered cutting my stock intake right at the first bend from the MAF sensor and just clamp both the pipes together but I didn't want it not to work and be out an intake, that would be horrible . So I never put mine on and it just sits in it's box it was shipped in cause I never knew what to do.
Old 08-17-2005, 07:32 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Man you shoulda saved your money. This thing is redicilous. Its the cheapest air intake on ebay and you will probably need a little more modifications to the car to make it fit. And how is it cold air if its sucking air from under the hood ? (where air is the hottest ???) If you are going to make a 92 Gs fast, my advise is to spend your money else where. Its just not worth it . I have an RS and I have so much stuff done to it and its still slow. Only way to make it fast is rebuild engine and turbo it. Thats what I am doing My idol engine ---->
http://www.gsturbo.com/gallery/showp...sort=1&cat=500
Old 08-17-2005, 07:44 PM
honestly i just wanted the sound from the mod intake, not to mention the pipe for my stock intake pipe melted so i needed to get something.
i like it plus the air filter is cleanable
its not for speed if i wanted to go faster i would turbo it
Old 08-17-2005, 07:51 PM
ned032002's Avatar
O I hear ya I really didn't care at all if the car performed better but that sound when you shift at high RPMs brings a tear to my eye.
Old 08-17-2005, 07:53 PM
hahahhahahhaha tears ehhh! lol
Old 08-17-2005, 08:11 PM
I have temporary AEM V2 intake and I have to say that bastard is hella loud man. I get asked a lot of its a turbo because of the intake sounds. It will be very soon (hopefully)
Old 08-17-2005, 08:13 PM
ned032002's Avatar
Even after I figured out that the hook up was not going to be easy I emailed the seller for instructions (of course they failed to send any). They claimed that the MAF sensor should just hook up to the little nipple on the pipe but that nipple is for the line from the Valve Cover. And since there was a no return policy on the purchase I was f#$ked.
Old 08-17-2005, 08:30 PM
well after i hooked it up the car fails to accerate. it bogs out immediately. i guess that map sensor is important i tryed to leave it out
so i cant get it to work. i threw the stock one back on and it works good. i duct taped the hole in it
Old 06-28-2007, 09:59 AM
Polishpat's Avatar
Polishpat Polishpat is offline
Send a message via AIM to Polishpat
Connect the cold air intake pipe into the base of the MAF and the cut the end off of the cone filter and place it over the MAF. Need good tools to cut end off of the cone filter though
Old 06-28-2007, 12:07 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Did you even bother reading the last posted date to this thread?... Almost 2 years old... Do not bring back threads older than a month unless you are the original poster or if you have some crucial information to add...
Locked...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Closed Thread
