Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-17-2005, 03:57 PM
ccbr01 ccbr01 is offline
96 T-Bird Squeaking Noise 3.8L
I'm new to this forum, so I'll keep my words short. Ok, there is a squeaking noise. I have replaced the belt, idler pulley, and water pump, and it still squeaks. What can it be?
Thanks
ccbr01
Old 08-17-2005, 04:34 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 96 T-Bird Squeaking Noise
One way to track down where a noise is coming from is by using a LONG screwdriver with the tip placed at various locations while placing the end of the handle against your ear. Just be careful of moving parts!
Old 08-17-2005, 04:39 PM
Re: Re: 96 T-Bird Squeaking Noise
did that check and it is coming from the a/c compressor. is there something i can do without paying 400+ dollars?
Edited: The a/c still works
Old 08-17-2005, 09:14 PM
coondawg6 coondawg6 is offline
check if you can put a belt on for "without ac option" --works for many cars im just not sure on yours
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 08-17-2005, 09:21 PM
I can't do that. It would be very loose
Old 08-18-2005, 01:12 PM
Justinjj727 Justinjj727 is offline
Send a message via AIM to Justinjj727 Send a message via Yahoo to Justinjj727
goto you parts store and get an oil charge for your system.. not the bottle you pour in but the bottle you can connect to your ac port. See if that doesn help.
Old 08-18-2005, 07:55 PM
not using same belt -duh-buy a different belt for without ac
Old 08-18-2005, 07:56 PM
there is not one available
Old 08-18-2005, 08:08 PM
you would need to experiment-measure belt and get a shorter one and see how that fits and go up or down accordingly....you could take a piece of small diameter rope and route around pulleys and cut at exact length take to auto zone and they will measure for you
