Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 08-17-2005, 03:28 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
help for sunday
FDTT and any others, me and jake are going to with luck fix my overheating problem sunday, were going to tear into this bitch. so what i need is for u guys to list any things u can think of that might caz this thing to overheat.. thanks
Old 08-18-2005, 03:24 AM
FDTT FDTT is offline
Re: help for sunday
running lean
timing is incorrect
incorrect rad
pressure loss due to old hose/cracked tanks ect
blocked coolant passages
poor thermostat
clogged pre-cat
There are ALOT of things that can effect cooling in a car. Just start with basics and if nothing arises start on the more complex things. Inspect the cooling system in detail. Pressurize it ALOT and see if you can find any leaks, or swells.
Then work up from there.
Dont drive faster than your angels can fly
Old 08-18-2005, 08:11 PM
Banned
Re: help for sunday
the timing and precat can make it overheat??????
Old 08-19-2005, 03:27 AM
Re: help for sunday
yup
I have run into it from time to time.
The pre-cat just ends up holding alot of exhaust pressure where you dont want it. Then the block takes on the heat and its transfered to the coolant.
Timing can play a big roll in overheating, but chances are its a combination of two or more of these issues causing the problem.
Old 08-19-2005, 07:41 PM
Banned
Re: help for sunday
thanks FDTT uve been like the biggest fuckin helper, but unforchantly with my luck its not goin to be that... but we'll find out sunday
Old 08-19-2005, 11:07 PM
Re: help for sunday
No problem, glad to help where i can. Never hesitate to ask, someone on here will know the answer to the question im sure.
