Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 08-17-2005, 02:38 PM
n8s95gsx n8s95gsx is offline
bezel install help
I just recieved a new bezel thingie to spice up my interior a bit
http://cgi.ebay.com/ebaymotors/Mitsu...93689039QQrdZ1
I am trying to figure out how to install this? I took out the 2 screws on the top of the black plastic piece that surrounds the glass and im thinking their are more screws on it because it wont budge! but where are they!
95 GSX 5SP
One of the many victims of CrankWalk
rebuilt motor from xtream motorsports of appleton
Balance shaft eliminator,manual boost gauge (15) OBX BG,OBX air/fuel,hard pipe and filter
dejon intercooler pipes with first gen bov
front strutt bar, 3" down pipe with cat eliminator, and custom cat-back from local shop.
ect...
Old 08-17-2005, 02:53 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: bezel install help
they are clips attached to the acual "glass" its only clipped in ,,,but no screws to remove to get that clear plastic peice out, its tricky cuz there is like 4 or 5 of them
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 08-17-2005, 02:54 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Did you physically remove the cluster from the car yet?
You need to remove the 2 screws underneith the top of the dash (in front of the gauges). Pull off the trim piece that you just unscrewed by lowering the steering wheel all the way. Then you have to remove 4 screws so you can remove the cluster. It just pulls out, no wires or anything. Then you will have to unsnap the clear plastic cover so you can get to the bezel.
Hope that helps!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-17-2005, 02:55 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Once the screws are out, pull the plastic cover straight out. There's little clips on the bottom that it clips into. Then there a 4 screws, 2 on top, and 2 on bottom of the cluster. Then, the whole cluster pops out. It's easier to take the plastic cover off first, then pull out the other half. Tere's only the 2 screws on the top of the black plastic. The the 4 on the rest underneath
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-17-2005, 02:56 PM
BOSTONjoe98gs
i didnt have to pull out the whole cluster when i did mine ,are you sure syder,ok bye
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 08-19-2005, 12:41 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
You don't have to pull out the whole cluster but it sure makes it a heck of alot easier...
I did some custom airbrushing (indy silver) on the outer ring and the bezel area on my old car so taking it out was necessary... here's a pic... I also plan to do it on my new talon.... jake permitting lol Not sure on a "color scheme" yet
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 08-27-2005, 02:46 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
I got the same bezel thing off ebay. Too bad it turned out to be some cheap wannabe chrome-'look' cardboard with a plastic face, lol.
The daily driver. The weekend cruiser. The lazy shop hog.
