Old 08-17-2005, 07:50 AM
dna59 dna59 is offline
What is this noise?
I drive a '95 Mitsubishi Eclipse RS and for about a week now I've been having a high piteched squeeling from my engine bay. Logically I changed the the power steering pump and a/c compressor belt. The noise was still there so we checked the tensioner, took it out and serviced it. The noise was still there, so I don't know what I should check next. The noise comes from the front area near the power steering pump. Could that be making the noise? and if so only replacing it will fix it? or could it be something else?
Old 08-17-2005, 10:50 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Did you check any of the other belts? It could be the main serpentine belt or the alternator belt. On my car the alternator belt squeels a little bit on moist days, but goes away after the car warms up for a few minutes.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-17-2005, 10:56 AM
Eclipsewhipping Eclipsewhipping is offline
Re: What is this noise?
ive had a simillar problem and it turned out to be a bolt that was wedge in the power steering pulley.
Old 08-17-2005, 11:35 AM
it is the main belt that i changed. i didn't change the alternator belt because the noise isn't comin from down in the area that is. Is centralled in the power steering pump area.
