Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 08-17-2005, 07:39 AM
client19 client19 is offline
Thumbs up 99gmc computer not sending emission info
I have a 99 gmc suburban that did not pass the emission inspection because the on board computer is not sending any info. they recommend that I drive it for 2-3weeks to reset it, but I work from home and do not drive many miles per week and I need to get the sticker to renew by tag by the 19th of aug. Does anyone know approx how many miles it will take to reset the computer ?? thanks
Old 08-17-2005, 06:54 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 99gmc computer not sending emission info
If they were checking at the DLC, there could have just been a bad connection with their tool.
There is no reset for the PCM and the PCM should not lose data unles there is a communication problem with the actual module itself.
I would have someone with a bi-directional scan tool check the module communication
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-18-2005, 09:55 AM
94 Jimmy 94 Jimmy is offline
Why not get your own OBDII decoder, check out:
http://obddiagnostics.com/index.html
or
http://www.scantool.net/
Both are under $100, and hook up to a cheap used laptop, PC or even a PDA. The Scantool decoder is only for specific manufactures, GM, Ford, Chrysler since each has a different way of sending the same information.
The obddiagnostics decoder will work on all of the OBDII cars. With this you can read all of the sensor info, the codes and it can be used to reset codes to see if they reoccure.
If the hundred bucks is too steep remember it's usually over that much just to have the dealer tell your that your gas cap is loose. Get together with some buds and chip in to buy one, eventually you'll all use it and be glad you had it.
See ya
94
