Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-17-2005, 03:17 AM
yolner yolner is offline
Valve cover & intake gasket leak
I drive a 91 grand marquis wagon. My mechanic says it would cost around 500 to take care of the leaks. Obviously thats a lot of cash when youre dealing with a 600 car. Can a newbie with a haynes manual do this or not? Are there any walkthroughs online? Anything I should know before I give it a try?
Thanks
Old 08-17-2005, 08:26 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Valve cover & intake gasket leak
Haynes manual should do it for you. You will need to clean mating surfaces really good and have a torque wrench for installation. You can do this without removing the distributor, so timing will not be an issur. Just be careful when installing, cause you have to angle and slide the intake in under the distributor. Have fun and good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
