Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 08-16-2005, 04:40 PM
lnksword lnksword is offline
Send a message via MSN to lnksword
Fiero Engine Help
I just bought an 86 fiero gt and I was wondering if anyone can tell me what work I can do on the engine to get more hp out of it before I start puttin engine mods on it?
Old 08-16-2005, 05:02 PM
ctesla's Avatar
ctesla ctesla is offline
easy: turbo.
less than easy: V8 conversion.
least expensive: drive it, enjoy it, and research it, while doing your engine mods; one paycheck at a time.
and welcome to the forums.
there are MANY websites out there for the Fiero.
and the 2.8L has many performance parts you can buy for it.
headers, coil packs, and cams, plus more...
JET performance makes a decent chip for the ECM; they also have under-drive pulleys as well.
if you do decide to cam it, while you have the engine out, or lowered, might put into the budget, the alt., water pump, and timing gears, as well as a new serp belt. (as it would be ashame to put it all back in, then three months later, you're on your back, knuckles busted in the drive, changing something that was just right in front of you).
good luck in whichever route you go.
chris
nrt racing
Old 08-16-2005, 05:06 PM
ctesla's Avatar
if turbo is an option:
check out
squires turbo systems
on the web, as they have a uniqueeasy bolt-up, and also
IRM Fiero
makes a turbo kit, and I can get you a part number and ph# if you want.
chris
nrt racing
[email protected]
Old 08-19-2005, 11:39 AM
Ok thats cool but I dont know of any v8 that will fit in fiero.
Old 08-19-2005, 07:53 PM
ctesla's Avatar
Re: Fiero Engine Help
look up or search:
V8 Archie
or
Fiero Sails / Fiero Secrets
also a Hot Rod or Car Craft of (I think Nov?) 99,
Fiero with NorthStar Cadillac!
Old 08-19-2005, 08:05 PM
ctesla's Avatar
http://www.v8archie.com/
http://www.v8archie.com/jamie.htm
http://www.kewlgeeks.com/Ray/page2.htm
http://www.kitcars.com/Classifieds/A...sified_id=3132
http://www.angelfire.com/fl5/fiero/fierolinks_009.html
http://www.sportscarforums.com/showthread.php?t=3797
http://members.aol.com/m34chev/myhomepage/auto.html
http://v8conversion.com/
(plus 68thousand more sites to look at)
the small block chevy is the most common.
if you need some detailed info, let me know, I can send you a pic of mine and some helpful parts to have before hand.
hope this helps,
chris
nrt racing
'NUF SAID...
