Old 08-16-2005, 03:37 PM
slick_5.0 slick_5.0 is offline
Good mods?
Hey guys,
I've got an 89 gt and am thinking about adding a couple more mods in the next while. As of right now i have cold air, off-road h-pipe, 3.55 gears, pullies, and off course flowmaster mufflers. Not a lot, but i'm working on it. I'm thinking about getting cam work and getting aftermarket headers. Do these sound like good mods for where i'm at right now? and what manufacturers would you most recommend? what types of gains would i be looking at from cam work and is it worth it.
Thanks
Old 08-16-2005, 05:22 PM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Re: Good mods?
no those arent really good mods right now. but will add some sound to ur exhaust if thats wat u want. i would get a comp. mod a 70 mm. throttle body and a ported upper intake. im not sure about the cam because with some cars it is worth it and for some it isent and im not sure bout a 89 gt
Old 08-16-2005, 09:22 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Good mods?
Save yourself the trouble of a cam right now with your stock heads and intake. Get some 1.7 rr's and some lt's and call it a day. Heads, cam, and intake will follow that depending on budget. But dont forget about your fuel system and ignition ect. The more mods you do the more power you gain but if you run out of fuel or spark you could lean out and hurt your motor or wash your cylinder walls with fuel. Either way you could be looking at a rebuild. Set aside a goal hp and a budget that you can handle and go from there.
1969 Cougar
357w & TKO - 475hp
Old 08-16-2005, 09:53 PM
Re: Good mods?
what are you calling It's? sorry, i don't know what that stands for, i've been trying to think of it, nothing's come up.
Old 08-16-2005, 09:55 PM
Re: Good mods?
does anybody know if it's worth modifying the stock heads or would it be better to buy aftermarket.
Old 08-17-2005, 01:59 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: Good mods?
You're best off with aftermarket heads. Even a good set of GT-40p's off an explorer is far better than home-ported E7's, or even E7's with some home porting and big valves. Save up for some Edelbrock, Twisted Wedge, or AFR aluminums.
By LT's he means Long-tube headers. Foxbody's are pretty easy to work with for LT's, and there are several on the market.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 08-17-2005, 03:43 PM
351wStang's Avatar
Re: Re: Good mods?
My luck has been that I run into to many problems with stock heads to waist my time & money with them. I've had cracked heads, push in studs push out, crappy port work done by what was supposed to be an awsome machine shop..and the list goes on. Save some time and spend just a little more cash and get yourself something to be proud of. Most box stock aluminum heads are worlds better than ported stock heads.
1969 Cougar
357w & TKO - 475hp
Old 08-23-2005, 01:42 AM
Re: Good mods?
Any head recommendations? Edelbrock?
