Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 08-16-2005, 01:25 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
just bought a 93 wrangler
last night I picked up a 93 wrangler, it's got the 4.0 6cyl, with 5spd manual trans. the spedo and odometer do not currently work. dose anyone know if the 93's used a actuail spedo cable, or if they use a sensor ???
thanks,
Keith
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 08-16-2005, 01:32 PM
bf1049 bf1049 is offline
Mine doesn't work, either. I have a '93 Wrangler with a 2.5 / 5-speed. Must be kinda common. I believe these Jeeps have a speed sensor, and electronic speedometer, not a cable. I haven't fixed mine yet, so I'm not positive, but that's what I was told.
Old 08-17-2005, 09:12 AM
pat8942 pat8942 is offline
Re: just bought a 93 wrangler
I had the same problem on my 92 and found the problem to be the printed circuit on the back of the speedo.
I just made a jumper and fixed mine.
Old 08-19-2005, 02:48 PM
pat8942,
could you give me some more information on those jumpers you made?
thanks,
Keith
Vehicles:
1987 Grand Wagoneer
Old 08-23-2005, 10:11 AM
Re: Re: just bought a 93 wrangler
Originally Posted by scoutinkeith
pat8942,
thanks,
Keith
I'm attaching a diagram to help you locate the problem.
On mine I had no ignition feed to the speedo so I made a jumper to connect the ignition feed from the tach to the ignition feed of the speedo and tucked the wire in the groove at the bottom of the cluster.
You can use an ohm meter to check continuity between the plug and the speedo and that will tell you how to fix it.
Hope this helps
http://files.automotiveforums.com/ga...82DASH-med.JPG
Old 08-25-2005, 10:49 PM
89ltd 89ltd is offline
go under the jeep and locate the speed sensor, if its a cable, then its a cable, if there are just wires, then its not a cable....
Old 08-26-2005, 07:55 AM
well, I did finally get around to crawling under it to check out the spedo. it's just wires and a sensor, and the wires all look to be ok under the jeep. hopefully this weekend I'll have time to pull the dash and check the wires there.
pat8942, thanks for the diagram, I'll check that out this weekend as well. hopefully putting in a jumper will take care of it, but if not, I think I may need to find a new spedo.
Vehicles:
1987 Grand Wagoneer
Old 08-29-2005, 07:52 AM
many thanks to pay8942!!!!
I pulled the part of the dash with the spedo, tach, and message display, and installed a jumper like you described in the diagram, and my spedo is now working again.
thanks again,
Keith
Vehicles:
1987 Grand Wagoneer
