Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-16-2005, 12:00 PM
bigmike224 bigmike224 is offline
1994 Lincoln Trunk Problems
I am having problems closing my trunk. When I usually close the trunk it will close manually. Now when I try to close it the little noise that I hear doesnt come on. Do you know what the problem could be?
Old 08-16-2005, 12:57 PM
Towncar's Avatar
Towncar Towncar is offline
The pulldown motor stopped working. There's several things in the pulldown assembly that can cause it to stop working.
I can't remember if it's fused, but if it is, it's sharing power with some other devices, is anything else not working?
If that's true, check the fuses first.
The wires are visable when you look at the pulldown assembly. Check that their all connected.
There's several switches and levers that operate the switches in the pulldown assembly, one may be defective.
Unless your good with these type of devices, and even the best concede, you might find it easier and faster to get another pulldown assembly from a scrapyard and swap them out.
-Steven
1996 Town Car, Cartier
Old 08-16-2005, 02:18 PM
I look in the owners manual and I couldnt locate the fuse that would operate the trunk. By the way that the only problem I'm having. (know on wood)
Old 08-16-2005, 03:33 PM
Towncar's Avatar
Re: 1994 Lincoln Trunk Problems
By the way that the only problem I'm having. (know on ood)
OK, I've located the fuse, it's in the first link here.
Check the others as well, there's some diagnosis clues, and wiring diagrams.
Topic: 1993 TC Trunk pull down motor Fuse?
Topic: Trunk Release Solenoid
Topic: 88 town car & trunk pull down
Topic: Trunk pull down SOS
Topic: Power trunk pull down motor
Topic: trunk pulldown circuit question
Topic: trunk pull down mechanism
Topic: 1997 Town Car Trunk Problem
Topic: 1990 T/C Trunk Pull Down Motor, Need One
Topic: Trunk Problem - Town Car
-Steven
