Old 08-16-2005, 02:19 AM
hotteroddr hotteroddr is offline
94 z28 lt1
can anybody help this sick piece of shi...,starts up fine revs up a few times then tack needle flickers then backfires 1 time and engine lite comes on,runs a few more minuites then starts crappin out r p ms get lower and lower until it dies. ive changed dis. cap ign.mod. coil the comp will not put out any codes. so i bought new comp. and still does same thing fuel pump is good o2 sencers r good catl.converter not cloggedfuel filter is new really getting stressed out on this thing does anybody know what 2 check next. what could it b. car is just sitting help help
Old 08-16-2005, 02:21 AM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: 94 z28 lt1
me-cha-n-ic:
One who specializes in motor vehicle repair.
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 08-16-2005, 09:11 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 94 z28 lt1
If the check engine light is coming on, the path to your answer is there and must be determined, shotgunning parts is not going to do much but make the parts counter guy happy as day as he rings you up.
Now, how are you attempting to access the ECM to obtain the trouble codes? Jumping a to b isn't going to work, this is a OBD I hybrid. You need to view the codes in live data stream.
It soudns like you've done some routine checks already which is good. But, the problem is something in the engine mgmt. system is awrye.
Old 08-16-2005, 11:23 PM
hvypdl hvypdl is offline
Re: 94 z28 lt1
Find somebody with a scanner. Freakin' hybrids. I have one also, and for a while I thought my computer was shot. I'm sure glad I read up on it on the internet because I was about to buy one.
~By the way, in my quest for wisdom I found some really good sources for ALDL software hacks to hook up to a laptop or even a crappy shop PC. Lots of free downloads for read only and read/write. The only hitch in the deal is you have to buy their cables to use the software. I think they run about $50 or so. Not a bad deal when you figure what a scanner can go for. Just gotta be careful not to upload porn onto your car's PCM or something silly. Once you flash it, it's gone and you better have the right program or you will be walking. I am thinking about getting a spare PCM from a junk yard to play with. Sounds cool.
Old 08-16-2005, 11:43 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Re: 94 z28 lt1
Originally Posted by Xenostalgia
me-cha-n-ic:
Xeno not everybody on this forum is as lazy as you.. sorry
Old 08-17-2005, 02:21 AM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: 94 z28 lt1
I just had the same problem on a 93 TA. Did you change just the dis cap and rotor or the whole optispark? I put a whole new optispark in mine and the problem went away.
Oh check your MAF sensor, get some carb cleaner and clean it if its dirty. Make sure you take it out of the car when you clean in and make sure that all the cleaner dries before putting it back in.
Maybe you got a bad load of gas. Does the fuel smell funny? Or look yellowish? I had a 94 Z that had bad gas in it when I bought it, would pop back through the intake then run like sh&t and stall. I drained the gas and put some fresh premium in it and a bottle of injector cleaner and it ran better.
Old 08-17-2005, 02:24 AM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Re: 94 z28 lt1
Originally Posted by 96CamaroSS
optispark
That is what I was thinking.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 08-17-2005, 09:26 PM
Re: 94 z28 lt1
Has anyone tried the new cap and rotors from MSD for the optispark? I ordered one from Summit when they first published it in their catalogs. The kit only runs about $150. I ended up cancelling the order because they couldn't even get it for another couple months at the time. I had to order an original GM unit and pay through the nose. That hurt. Cured my problem though (which sounds alot like the original post here).
I was just wondering how it worked out and if anybody knew anything more about it since it sounds like they did away with the original high/low resolution trigger setup. I wonder how that ties in with the signal coming from and back to the PCM. I don't remember it saying anything about off-road use only, so it must somehow to be emissions legal.
I have been affraid to clean my MAF since I saw the price of a new one. I had hoped carb cleaner would work, but was just being a tight-wad sissy. I think I'll take the little tube off the spray nozzle to spread out the spray pattern since the pressure could probably break that little filament lookin' thing in there just to be sure.
