Old 08-16-2005, 01:36 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Ground Wires
I was just surfing ebay and found these....
http://cgi.ebay.com/ebaymotors/TRUST...QQcmdZViewItem
Does anybody have these installed on their car? Did you notice any difference? I did a search and only found 1 thread that was relevent, and kevin had posted a shit load in it but I didn't follow a lot of it....I must be retarded.
I'm not looking for a huge performance gain or anything, it just looks like a cheap mod that might have some little benefits if it does what they say. The other thing is, how exactly do you hook up something like that? I don't see any wires like those around the battery, but I didn't look all that close. Pics would be appreciated if somebody has them handy. Thanks guys.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-16-2005, 03:38 AM
Whathits14 Whathits14 is offline
Re: Ground Wires
Don't bother. You can make your own ground kit for like $10, it really doesn't do a huge amount. Maybe allow your lights to stay a little brighter when all your other electrical shit is turned on, but asides that it really doesn't do a whole lot.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 08-16-2005, 06:25 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Ground Wires
Mine are coming in today actually. It's cheap enough... why not try it?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-16-2005, 11:53 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I read an article once about grounding systems in Modified Mag, Import Tuner, HCI, or something like that. They dyno'ed a car with and with out those... there was like a small increase in hp... maybe like 3-4. So it wouldnt do a lot of good, but would probably help. Like david-b said, it is only $23 shipped...
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-16-2005, 12:33 PM
Hey david you will have to let me know how you hooked it all up, because I have no idea where to start. Pictures would be awesome! I plan on getting them soon because they are really cheap, why not.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-16-2005, 02:01 PM
david-b's Avatar
Dave is THAT guy
Re: Ground Wires
Yeah, when I install them ill take pics and do a writeup for you all. Didn't get today, so maybe tomorrow.
75 Monte Carlo
Old 08-16-2005, 05:18 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: Ground Wires
What you do is take your factory grounds off and replace them with the new ones. there are grounds all over the place.
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-16-2005, 05:37 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Ground Wires
that big head in the one you posted is the stupidist piece of crap ive ever seen. i wouldnt be surprised if it hit the bottom of the hood. there are much cheaper and easier ways to get the same results. just buy 10 ft of battery cable and some terminal ends and replace all of your stock grounding straps.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 08-16-2005, 06:02 PM
Re: Ground Wires
IMO if i got one it would be the Apexi one (little box) and lights up Apexi. Cost is more but you get what you pay for! Ebay... An ashtray with holes drilled in it for your new pretty wires..
2002 VW Jetta 1.8T
Old 08-17-2005, 08:18 PM
david-b's Avatar
Dave is THAT guy
Re: Ground Wires
I got the wires today. Ummm, yeah, they're a big piece of shit. The wires themselves are good, thick, and nice. The head piece is WAY TOO BIG!! My strut bar goes right over the negative battery terminal, so the massive head piece is too big. I had todo a little customization to make it fit. The head piece with the logo is kept off. I was installing it, but I accidently blew my alternator fuse, and cant get some until tm. I do have 2 wires installed, one going to the firewall, and then one going to the intake manifold. Have to lift the car to find the rest, (I think). Ill take some pics tom and post them up.
75 Monte Carlo
Old 08-18-2005, 12:50 PM
Sounds good, I will check back.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-18-2005, 12:55 PM
david-b's Avatar
Dave is THAT guy
Re: Ground Wires
Where is there a negative wire going to the alternator? Also, where is there a negative wire going to the headlights? I dont see any
75 Monte Carlo
Old 08-19-2005, 10:48 AM
tr10av tr10av is offline
Send a message via MSN to tr10av
Re: Re: Ground Wires
In this DSM Tuners write-up it says that you do hook one up to the alternator, but it doesn't say anything about a headlight ground. It has pretty good pics for anyone wanting to do their own and not buying one off eBay.
http://dsmtuners.com/forums/showthread.php?t=75889
Old 08-19-2005, 02:37 PM
david-b's Avatar
Dave is THAT guy
Re: Ground Wires
Nice. I shouldve probably just made one on my own. There wasnt nearly as much wire to do all of that. I might just pick up some wire and finish the rest myself. Thanks
75 Monte Carlo
