Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-16-2005, 01:08 AM
Prime First's Avatar
Prime First Prime First is offline
Send a message via AIM to Prime First
I have a pretty good-sized problem.
Hey guys, I got a problem. Hopefully someone can help me out.
I have a 1999 420A Eclipse. I've been having some minor engine problems here and there, mainly with the ignition...misfiring cylinders and such. But tonight my car stalls out and the oil light comes on. Of course, my power steering is gone and I'm stuck in the middle of a turn. So I get out and add some oil, since my oil consumption has gone up alot. I start up the car and head down the road after making sure that everything is ok.
But then my speedometer wont work and my transmission is stuck in first (4sp auto). Shifts into and out of gear are real hard, and engine revs change real slow. I drove the car to an Advanced Auto Parts and left it there. Because it's about 2 in the morning right now.
Anyways, I hope someone can tell me what's wrong. I've never had problems in the engine, transmission, and instrumentation all at the same time. I had added synthetic fuel injector cleaner into the gas tank recently to see if that would help out the misfiring. But that's basically all I've done different.
Thanks for the help.
Prime First
1999 Mitsubishi Eclipse
10th Anniversary Edition
Old 08-16-2005, 01:27 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Ummmmmm....ok well the first thing that comes to mind is checking the plugs and wires. Pull the plugs and make sure they are gapped to around .045-.050" and are not all corroded. Check the wires for cracking etc.
If that all checks out, check all your belts. It sounds like you might have snapped the main belt that runs the power steering and alternator. You have a lot of shit going on all at once, it's best to just try and diagnose them one at a time. Check your oil level while your at it, and your transmition fluid level. I don't know what else to tell you man, good luck and give us updates.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-16-2005, 01:33 AM
Re: I have a pretty good-sized problem.
Thanks for the advice, Eclipse. I'll check all that tomorrow, since it's pretty dark right now. I don't think it's the main belt though because I lost the steering since the car cut off. I'll get the engine codes tomorrow and post updates. Thanks for the help!
Prime First
Old 08-16-2005, 05:47 PM
Okay, I got the engine scanned today.
I have a P0700 transmision malfunction and a P0731 gear ratio read.
We did a transmission oil and filter change in the parking lot. The oil was unbelievably dark, probably from the first owner because I don't run it hard enough to do that. Anyways, 2.5 hours of work, and the car is still the same.
I'm stuck in first and the transmission is really rough, poppin in and out of gear. And my speedometer/odometer still don't work. Torque converter? Thanks for any suggestions.
Prime First
Old 08-16-2005, 06:18 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
for the tach and spedo see if the sensors are good? Tranny you might need a new one or a rebuild
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-16-2005, 08:11 PM
Re: Re: I have a pretty good-sized problem.
haha, damn. I was hoping for a solution other than that. Thanks
Prime First
Old 08-16-2005, 11:31 PM
Maybe your ECU is going bad? That would seem a little far fetched, but you have so many problems going on at once that that might seem logical. The ECU controls everything the car does, and if that goes crazy, so does your car. Check that and get back to us.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-17-2005, 07:40 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
The ECU has nothing to do with the tranny....it is controlled by a seperate computer, the TCU.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-17-2005, 11:03 AM
My bad.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-22-2005, 12:44 AM
Guys, I pretty sure that my torque converter is messed up. Does anyone have any experience with torque converter problems? My transmission is stuck and it keeps stalling the engine.
Also, I have the habit of shifting the transmission into neutral at stops. I do this to reduce friction at the brakes and all the moving parts in the transmission. I don't see the point in having the engine engaged at a stop and having to hold the car in place with the brakes. Not many people do this...so do you think this led to my premature TC problem?
Prime First
Old 08-22-2005, 10:41 PM
It really isn't wise to do that. Theres really no reason. You are putting more stress on the tranny by doing that rather than leaving it in gear using the breaks, because thats just one more shift into drive that you have to do at every stop. Just keep it in gear, that's how it is designed.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-23-2005, 01:10 AM
oh dammit Thought it was a taxi cab driver's trick.
Prime First
Old 08-24-2005, 06:10 PM
ae9803 ae9803 is offline
Not much of an expert but when i drove a 2000 celica i had the same problem and believe it or not it was the wiring harness... a fucking rabit ate up some wires underneth the car... Maybe you have the same deal? Dunno thought id bring that to mind
Old 08-25-2005, 01:24 AM
Hmm...I'll keep that in mind. I'll probably take the car to Cottman's this weekend because it's the closest place to campus. And proximity is really important right now. Anyone heard anything about Cottman's? Thanks for the suggestions.
Prime First
Old 09-14-2005, 05:28 PM
Update
So, I got my car towed to Cottman's. They diagnosed and replaced my output shaft sensor. I went to pick it up and took it out for a run. I could tell once I got in the car that something wasn't right. I asked the manager why my car was running so rough, and he blamed it on my misfire, which I had before the transmission problem.
I took it back out with my friends following me. I ran the car at near-full throttle to make sure that the car shifted-properly. After less than a minute, my speedometer goes crazy and the car stops shifting again.
I took it back to the shop, and picked it up 3 days later. AE was right, it was the wiring harness. They replaced the wires, and now I'm back on the road.
Now for my new problem. Misfire in cylinder 4. It used to be cylinders 1 and 2. Then it was just 2. Now it's cylinder 4.
Prime First
