Old 08-15-2005, 09:48 PM
SSJSubgeta's Avatar
SSJSubgeta SSJSubgeta is offline
Send a message via AIM to SSJSubgeta
Exclamation Some Parts Q's HELP!
Ok im in the process of prepping my D15b Vtec motor and i needed some info/input on th following...(CRX HF 91)
1. I looked for a new fuel filter (part N# FF705) (Since im doing a swap i thought i should replace that as well) That part N# is for a CRX all models? does it matter if im putting a diffrent motor in or will that work?
2. I will like to know if i will need as well, replacing the PCV valve? if so what part N# is it for a D15b Vtec?
3. Radiator hose? will i need diffrent one's? I will be using the Stock radiator...also if you have part N# too.
thanks...
Old 08-15-2005, 10:55 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Some Parts Q's HELP!
Just go to the parts store and tell them you need a fuel filter but it should be the same for both, Just take the pcv valve in, they can match one to it - but it also should be the same, Stock radiator hoses should be spiffy.
Old 08-16-2005, 12:33 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea the only thing that may be different would be the pcv, but every thing else should line up fine.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
