Old 08-15-2005, 08:37 PM
doconnor21 doconnor21 is offline
Best way to free up spare tire cable winch
What is the best way to free up a siezed spare tire holder cable winch?
Old 08-15-2005, 10:47 PM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Best way to free up spare tire cable winch
I would think if you can't get to the winch from down below then you may be looking at taking the box off then you could at least get to the winch.
However, if you can see the winch from below perhaps you can tap it with a screw driver or a hammer and try and brake it loose....
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 08-15-2005, 11:06 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i would try to get to any part of the mechanism and squirt wd40 or some type of rust eater and lubricant and let is sit for a few mins, then try to lower and you may need to squirt it several times.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 08-16-2005, 12:00 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
I agree with sportin83. Get a good quality penatrating oil and soak the crap outta it and let it sit for a couple of hours and soak it again before trying it and if it does not break loose let it sit a bit longer. No sense in causing yourself more work in having to replace the winch mechanisim if you don't let the penatrating fluid work long enough. I mean it is not loke you can expect it to break loose possibly years of rust and corrision depending on if they use alot of road salt where you are in just a few minutes. I know here they use a ton of it in the winter and that is why i get all my vehicles rust proofed and under coated.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
