Old 08-15-2005, 07:00 PM
cmpyfrom cmpyfrom is offline
Cool What amp(s) do I need for 4 12" 600 watt max subs???
I have a box with 4 12" MA Audio 600 watt max subs, and I want the best performance out of them. Should I get two amps and hook up two subs to each amp, and if so, how many watts should each amp have? OR, should I get one big amp for all four speakers? If this is the right option, how many watts should my one amp have? Should it be a mono amp, or other? Thanks!!
Old 08-16-2005, 07:59 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Are the subs 2 ohms, 4 ohms....Dual Voice Coil (DVC) or Single Voice coils (SVC)? What is the RMS wattage oif each sub. This is far far more useful than Peak (Max) wattage is. Peak wattage is pretty useless, especially when choosing subs and amps. RMS is what you want to pay attention to.
So... 1) what is the rms wattage of each sub, 2) are the subs DVC or SVC, 3) what is the ohm load of each sub, 2 ohms, 4 ohms?
These are ALL things that you need to know before you choose an amp and wire the subs up.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 08-18-2005, 08:05 PM
They are 4 ohms stable, DVC and the RMS wattage of each sub is 300. Thanks for your help!
