Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-15-2005, 06:51 PM
pichichus pichichus is offline
Question won't start
this is weird,,i went to pay my cable bill and 5 minutes later i was trying to go home but my car decided not to start,,,all I hear is a little click behind de radio,,nothing in the engine compartment,,it's a 90 eclipse 1.8,,,,,i'll apreciate any advice in this matter,,,thanks,,luis
Old 08-15-2005, 07:34 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Is it a fast click? If so that could be your battery. Or is it just one click...maybe your starter? Please be more descriptive.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 08-15-2005, 09:27 PM
Re: won't start
Its jusk one click,.....my battery voltage is good,,,,,,,
Old 08-15-2005, 10:30 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: won't start
The ecu makes a click when you turn on the car (usually your starting so you don't hear it) So thats probably the click. Check if you starter is getting power if so then take it to autozone and have them test it.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-15-2005, 11:13 PM
efosa efosa is offline
My 99 Nissan Senta turns but won"t start.
My 99 Nissan Sentra turns but will not start after the old engine was replaced with another used engine. It is a GA16DE engine (both are), There is voltage on terminal 5 on the camshaft Position sensor. Also there is voltage on terminal 1 on the crankshaft position sensor. However, there is no voltage on terminal 7 to the coil. But the IGN SW is okay and the ECM relay is fine.
The ECM sored code 21 or 0201 which means that the "the ignition signal in the primary circuit is not entered during engine cranking.
Could some tell me what to do in order to get voltage to the coil befor I go crazy?
Goodluck.
Old 08-16-2005, 07:17 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: My 99 Nissan Senta turns but won
Cut terminal 5 on the CPS and wire in a 30 Ohm resistor before attaching it to terminal 7 on the coil. Cut terminal 7 and ground it to the firewall. Next grab the end of the spark plug wire and have a friend try to start the car.
Let us know how it goes!
How the fuck are we supposed to know.....go to the Nissan forum and ask.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-17-2005, 04:58 PM
Re: Re: won't start
Thanks for the tip.....monday after midnight i decided to check all my fuses and relays,evething was fine,played around with every single conector just to be sure they were tight,gave it a shot and ,magic,,,the car is running again,,dont know yet what was wrong ,,,,,thanks for your time,,,,,,,,,
