Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 08-15-2005, 06:46 PM
winkleboy winkleboy is offline
Question 92 Golf GL wont Fire-up w/out starter fluid
My 1992 Golf GL ran kinda rough one day, and after i got it home i could not get it started.
I've used starter fluid to get it running, and it runs great.
But once i stop it, i cant get it started again w/out starter fluid..
It'll turn over just fine, but it wont fire up.
I thought it might be the Air Mass Meter, which i replaced after finding
one at a junkyard.
That was not the answer.
Could it be the Idle Stabilizer Valve?
(which seems to have an odd 'buzz' to it when attempting to start--not sure if that is normal...)
Any thoughts.
Its been this way for about a week now.
-Stumped.
Old 08-15-2005, 09:02 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
IS it getting fuel to the fuel rail.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-16-2005, 01:59 PM
Re: 92 Golf GL wont Fire-up w/out starter fluid
My gut is 'yes'.
But i'm not certain.
Is there a quick way to determine if it isn't?
Old 08-16-2005, 03:52 PM
austin[rock] austin[rock] is offline
id say its a gas issue
see if your getting fuel
could be one of the fuel pumps there are two of them
Old 08-21-2005, 02:53 PM
Re: Re: 92 Golf GL wont Fire-up w/out starter fluid
That would be great if that was all that it was.
Would that explain not only the difficulty in starting it, but
also the roughness of it when it does run?
Old 08-21-2005, 08:19 PM
boschmann boschmann is offline
Another thing is how old is the fuel filter?
Old 08-22-2005, 12:15 PM
I replaced the fuel filter about 5 months ago.
Also replaced a fuel injector around the same time.
Its always ran a little rough at first, but when it got
going it ran great.
I love the car.
Its just so frustrating not knowing where to go next.
Old 08-23-2005, 07:39 PM
Checking the fuel pressure is fairly easy with a simple gauge. There is a 7mm plug in the end of the fuel rail, remove & slip gauge hose over the nipple end. Pressure should be 40-45 psi running & should not drop below 25 psi within 15 minutes after shutdown.
