Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-15-2005, 06:08 PM
bstedman bstedman is offline
AC only blows out defrost vents
97 Dakota V6...has no vacuum coming to the back of the AC control..tried to trace it out under the hood and could not find it...any one have directions on where the vacuum connects to the engine?
Old 11-05-2005, 06:07 PM
tyler005 tyler005 is offline
Did you resolve your problem? I'm having the same problem. Thanks
Old 11-07-2005, 07:13 AM
Re: AC only blows out defrost vents
Yes I did...the vacuum line from the firewall to the heater control had a leak. Somehow the line developed a crack.
Old 11-07-2005, 08:59 PM
Re: Re: AC only blows out defrost vents
Where is that line located? Thanks
Old 11-08-2005, 07:31 AM
Re: Re: Re: AC only blows out defrost vents
The line enters the passenger compartment, from the engine side, just to the left of the brake booster. It usually is a very small plastic line if it has not been replaced. On the passenger compartment side it is very hard to trace, especially if you have AC.
I found my leak by removing the vacuum line asm from the back of the heater control switch and putting air pressure thru the black line, which is the main line to the switch. I could then hear air blowing out under the dash. I bypassed the leak by running a rubber hose from under the hood to the back of the vacuum switch.
