Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-15-2005, 06:07 PM
impalass impalass is offline
Question 98 Neon with a stall problem
Hi everyone... I have a 98 dodge neon automatic. A couple of days ago it stalled while driving. It took a couple of minutes to start. Last night it happened again and it took me a long time to drive back to home. It keep stalling and I have to wait 15 or more minutes to started again. I check the codes and the only ones are 11 and 12. It start in neutral and park as normal. It goes in gear without stalling but if i give it some gas in gear...it dies and them it don't want to start for a couple of minutes. Fuel pump is OK. It sound for a couple of seconds at run and continuosly with the engine running.It don't have spark at the spark plug after it stalls but if I wait 15 minutes everything is normal. I'm running out of ideas.....anybody ever have this problem????
Old 08-15-2005, 07:07 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 98 Neon with a stall problem
That code 11 is bad news...Timing belt skipped 1 tooth or more from initial learned value; Intermittent loss of either camshaft or crankshaft position sensor; No crank reference signal detected during engine cranking. If your timing belt skipped a tooth, then you may have bent some valves. How many miles are on you neon?
Old 08-15-2005, 10:29 PM
Thumbs up Re: Re: 98 Neon with a stall problem
Sorry... it is code 12... the motor start ...runs ok at idle, but if I give some gas it stalls and dies. Them It won't start. I have to wait a while to tried again. Fuel pump is OK . I check for codes and 12 and 55 are the only ones. Any ideas?????
