Old 08-15-2005, 05:21 PM
Rob Rangel Rob Rangel is offline
Send a message via MSN to Rob Rangel
overheating 93
I own a 93 ext. cab with a 5.7 that has just started to overheat. Three days ago i saw that the "check gauges" light turned on and noticed that the temp was kinda high. I hadn't used it again till today, within a couple blocks the "check gauges" light came on and the temp was high, then later on teh "service engine soon" light came on. The temp was crazy high by this point, so i added coolant when i got home. later on i went back out and it stayed cool for longer, but eventually did the same thing. Upon returning home i parked and was then asked to move it. but when i tried to turn it on, it turned over but didnt start. im not sure what the problem is, and really need to figure it out soon. any help is appreciated, thanks
Old 08-15-2005, 09:36 PM
jveik jveik is offline
Re: overheating 93
well, id assume you have already checked this... but what the hey... is your thermostat stuck closed? my buddy bought an old ford ranger and had to drive it maybe a mile home and he had a stuck thermostat which caused him to melt the undercoating off the bottom of the firewall lol
Old 08-15-2005, 09:38 PM
Re: overheating 93
also, make sure the radiator fins are for the most part in good shape. its amazing how much worse it will work if a major percentage of the tiny fins are damaged by the bugs smashing them silly
Old 08-17-2005, 02:49 PM
Fireplug Fireplug is offline
Re: overheating 93
YO guys check the easy things first.
Is there any coolant in the rad???if not fill it up.
any engine oil in the engine???
How long did you run it hot ??? does it crank over at all ??
