Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-15-2005, 05:06 PM
zeus999 zeus999 is offline
Exclamation how to get more horsepower
how do i get more horse power out of my 1996 eclipse GS
garages told me that the engine has to low compression for a turbo
Old 08-15-2005, 05:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: how to get more horsepower
It has too high of compression for a turbo. Turbos need low compression. Everyones going to say to pull the engine, rebuild the internals, and add a turbo.
How much are you looking for? If you want some, do the basics first... FULL exhaust (header, high flow cat, cat back), intake, ignition, and a U/D pulley. These will get you the most power right away, and for rather cheap. Intake manifold will help more, TB, and a good tuning wioll do good too. Bigger FIs, fuel rail, fuel pump, and again tuning will get you the most.
If you want instant power, go with a turbo (that's right, I said that). lol
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-15-2005, 05:16 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-15-2005, 07:58 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Low compession is great for boost, but high compression built 'race' motors don't fare too badly either... the 6-bolt block I just purchased has a 9.1:1 compression ratio (which I thought was kinda high too), and boost should be limited at 25-30 psi on it. The 9200 RPM redline certainly makes up for the boost limitations though , so even a high compression ratio with strong internals and a solid block ought to get you going pretty fast.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-15-2005, 08:44 PM
david-b's Avatar
Dave is THAT guy
But that can get expensive. Raising the compression and rebuilding everything is a bitch and a half.
Again, if you want to do basic boltons, I stated them above. If you want more, we got that too!
75 Monte Carlo
Old 08-16-2005, 01:00 PM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Re: Re: how to get more horsepower
Why don't you just sell the GS, and get a fricken turbo for like 5,000. It's not like there aren't any left on the planet. Why would you do ALLLL that work and not even have as much accel and pull back as a simple GST...I just don't get it. Unless you just like doing it, then it makes sense.
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 08-16-2005, 02:10 PM
SmicAA72
Guest
Posts: n/a
1. You lose money on buying, then selling a car. More owners, less value.
2. Maybe he doesn't want to wait around for a good buyer. Sometimes that can take a very long time.
3. Maybe he has already done work to his car. As for me, I already have body work done, why would I go and sell it, thus losing ALOT more money than I'll be saving.
4. Availability of turbo DSM's. No, they are not everywhere. I would most likely need to drive hundreds and even thousands of miles to get to one, no-can-do.
Old 08-16-2005, 06:46 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Add some spray.. 75shot max
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-16-2005, 08:01 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
I drove about 3 miles tops to get mine dealership had it for 6k, i got em down to 4600, 79k miles and only needed plugs/wires
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 08-16-2005, 10:31 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
I flew 1500 miles for mine
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 08-16-2005, 11:10 PM
I drove 749 miles for mine
2002 VW Jetta 1.8T
Old 08-16-2005, 11:43 PM
I don't know how this thread got switched up like this but oh well.....
My car was brought to me by the guy that bought it at an auction that worked for a dealership. I only had to drive 12 miles to the dealership to pick it up, and paid $300 over what he paid for it.
As for the topic of this thread....
If your loaded with $$$....get a turbo kit...get you to 220 hp (estimate)
If you are limited with $$$....intake, header, exhaust, ignition, udp....get you to 180 hp (estimate)
The turbo kit will cost anywhere between $1,500-$3,000 depending on a lot of factors. The shit I listed with the *limited* budget you could get and install everything yourself for less than $1,000.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-17-2005, 12:58 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
i went flew 1100 for mine and drove all the way back
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
