Old 08-15-2005, 04:09 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Installing 95 E-PROM ecu on '99
Whats involved in swaping stock '99 GST ecu, with a stock '95 GSX ecu? (E-prom) i'm hoping to run DSMlink, that is the only reason for the swap. Also i heard that the E-prom can pass emissions with out a cat? is that true? because, if so... tha would be pretty usefull. Also, what could i expect to pay for the Eprom ecu? thanks guys.
Old 08-15-2005, 05:09 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Installing 95 E-PROM ecu on '99
$200
DSM geek
Old 08-15-2005, 05:32 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
You will need to use the cam sensor of the 95 to make things easier. If not you will have some problems starting up the car. the cam sensor is behind the cam gears, and you should remove 1 of the cam gears to get access to it.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 08-15-2005, 07:45 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Holy shit black shadow i havent seen you on here for a while. welcome back! How is that gst>gsx conversion?
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 08-15-2005, 10:23 PM
Black99GST's Avatar
$200 new from Mitsubishi? wheres the best place to get the computer... and the cam sensor? just a junk yard? Ebay? lol where you guys suggest? *anyone on here wanna sell me one?*
Old 08-16-2005, 12:12 AM
Re: Re: Installing 95 E-PROM ecu on '99
I haven't been here for a while, the forum was changing too much and i didn't like those changes, i hope that now with the new people everything should be better.
Well all the swap is done, the car is running really strong, i just need to paint the 97 front and rear bumpers, so i can complete the 97 conversion.
In this picture you can see the difference between the custom red i used and the stock red.
But the car is running great, i already test it in a little race against a 2000 something corvette, and my Gs-Tx really impressed me, but as i said it was a short race so he could make too much speed.
Returning to the topic; the cam sensor you should try at the junk yard, and the ECU, you can try on Ebay, you have to be really lucky to find an eprom at the junk yard.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 08-17-2005, 10:20 AM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
Are you guys sure you need a cam angle sensor for a 1995 ecu, It is still a 7bolt 2g. I thought all the 7bolt 2gs came with a crank angle sensor.
Old 08-17-2005, 11:09 AM
SpyderGuy97's Avatar
SpyderGuy97 SpyderGuy97 is offline
Send a message via AIM to SpyderGuy97
According to this site i found on Vfaq: http://www.darklightning.com/gi/1gvs2g.htm
the 95 doesnt even have a cam angle sensor.
Zack
Old 08-17-2005, 01:19 PM
kjewer1 kjewer1 is offline
AF - Advisor
All 1g and 2g cars have a cam angle sensor. The 1gs do not have a crank angle sensor, this signal is still required by the ECU, but is generated by the cam angle sensor. For ODB2 misfire detection the 1g cam/crank signals are inadequate, hence the randmon misfire CELs when using a 1g cam/crank sensor on a 2g.
The only needed for the swap is to reverse the order of the plug wires on the coil pack. Put 1 and 4 on the 2/3 coil pack, and vice versa. The injectors are also out of phase, but the effect is minimal. With DSMlink, select "Invert CAS" to fix this. You can even have the DSMlink defaults setup for inverted cas. The magnus or RRE site for 6 bolt swaps describe how to actually rewire the injectors at the ECU, and this was what I had done long before DSMlink.
The best place to get an Eprom ECU is on DSM forums. They come up for sale just about weekly. 250 is the going rate, but sometimes you can get them cheaper.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-17-2005, 09:45 PM
macder macder is offline
Send a message via MSN to macder
Don't know much about ECU compatibility within the different years, but looking at OEM part#'s, every year from 1990-1999 has a different part # for the ECU.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 08-18-2005, 02:39 PM
AF - Advisor
90 is an odd year, 91-94 are interchangeable, 95-96 are the same, 97-99 are the same, 95-96 and 97-99 are interchangeable with the plug wire swap. For 1Gs only, there is also a difference between auto and manual tranny ECUs since autos came with 390 injectors. You can swap them, as long as you compensate accordingly with an AFC or similar. The FWD ECUs (might be 2g only) have a speed limiter that the AWD ECUs dont have. I think thats it for ECU differences...
Kevin Jewer
Old 08-18-2005, 03:27 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
There is a site you can cut the limiter on a FWD ecu pretty easy to do!
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-18-2005, 06:21 PM
Black99GST's Avatar
will DSMlink work with the stock '99 computer, i would like to do what mitsu_eclipse95gst said... and just cut out the speed limiter. would this work just as good?
Old 08-18-2005, 07:15 PM
The 1g ECU don't have a speed limiter, but it triggers fuel cut @ 7500rpm.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 08-18-2005, 07:47 PM
No you can not use your 99 ecu with dsm link But you can remove the limiter.
Here is the link IF you want to take your speed limiter out. See if you can find a FWD ECU cheaper and do the mod to that ECU. Turn it into a GSX ECU
http://www.dsm.org/how-tos/speedlimiter.htm
Do this at your own risk
2002 VW Jetta 1.8T
