Old 08-15-2005, 02:59 PM
gfriot1 gfriot1 is offline
Location of Oxygen Sensor for 1998 S-10
Hello. I purchased a 1998 Chevy S-10 4 cyl. last year from a private individual. The guy had taken off the Catalytic Converter and in doing so also removed the Oxygen Sensor. I have put on a Catalytic Converter but I am not sure where the Oxygen Sensor needs to go. I need to do this for my NYS inspection. I found the plug in, I think but I have no idea where the sensor itself is supposed to be put after I plug it in. Any help you are able to give me would be greatly appreciated. Thank you in advance. George
Old 08-15-2005, 10:55 PM
Wags391 Wags391 is offline
10-year Owner
Re: Location of Oxygen Sensor for 1998 S-10
On my 92 blazer the o2 sensor is located just before the cat convert beside the trans pan if tat helps.
Old 09-14-2005, 07:08 PM
rdfirbird92 rdfirbird92 is offline
Send a message via Yahoo to rdfirbird92
the cat should have a pipe 12"-18" attached to the ass-end of it. the actual converter and this pipe should be one piece. the 02 sensor goes in a hole in the begining- middle of the pipe section. the sensor will point toward the driveshaft once installed.
01 dodge stratus R/T 3.0L v6 5spd
underdrive crank pulley, Eibach Sportlines
Fidanza stage 3 clutch, Fidanza lightweight flywheel NO MUFFLER
http://s72.photobucket.com/albums/i1...mperfixed2.jpg
R.I.P. 12/19/05
'98 s-10 2.2L 5spd daily driver
2/3" drop, K&N filter
Pacesetter header
high-flow metallic cat.
flowmaster 40 series
BFG G-Force T/A KD's
Old 09-17-2005, 01:09 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
pick a spot, just behind the cat, thats where it goes, rdfirbird said its suppose to face the drive shaft, but thats incorrect, ive been under quite a few of theses trucks, and also under my personal one plunty of times, they point in any given direction as long as the sencor plug reaches you are fine
