Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-15-2005, 02:45 PM
dogsgone dogsgone is offline
2001 Dakota Blower Motor
Blower motor does not work, at first it would come on and then quit after awhile. (it doesn't work at any speed) Now it will not come on at all, Resistor pack and blower motor are "O.K.", There is no power to the harness that plugs into the Blower fan switch. Also you can turn on the A\C and it will come on with no blower, when it is working properly and the blower switch is shut off you can not turn it on. I have checked fuses and relays and cannot find a problem. Any help would be appreciated. Thanks
Old 02-07-2006, 10:10 PM
EricinTN EricinTN is offline
Re: 2001 Dakota Blower Motor
I had the same problem. I replaced the resistor pack and it fixed it. It only
costs about $15 at the dealer, so it's worth trying. Even if it doesn't fix it you at least get a chance to check out a new Charger in the show room.
