Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-15-2005, 02:24 PM
cmkrup cmkrup is offline
Unhappy alternator??
My '95 Buick Regal with the 3800l eng has an intermittent battery light coming on. I put a tester on the battery and it only had 115 CCA so I replaced it. The battery light continued to come on intermittently. I put a multimeter on the battery with the engine running and the readings were erratic, but with the battery light on it was reading 16+ volts.
Is it a safe assumption that the alternator is overcharging and requires replacing?
THANK YOU!
Chris
Old 08-15-2005, 05:25 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: alternator??
Sounds like the regulator inside the alternator is bad. If it is charging 16V, you better do somthing quick or else you will have a host of electrical problems.
Old 08-15-2005, 11:28 PM
regalfriend regalfriend is offline
Re: alternator??
16 volts is too much...more common when the alternator goes bad they undercharge...i had a car that overcharged...i noticed it because , at night, the dash lights looked like Times Square......
