Old 08-15-2005, 01:03 PM
bballprep2004 bballprep2004 is offline
Send a message via AIM to bballprep2004 Send a message via MSN to bballprep2004 Send a message via Yahoo to bballprep2004
way too much play in shifter PLEASE HELP!
i just recently had my 95 civic ex changed over from automatic to 5 speed. and i love it dont get me wrong. but i have a huge complaint/problem and i need some help. i installed a short throw shifter nothin too fancy or nice but it gets the job done however when in neutral the play is not normal it goes left to right probably 2-3 inches either way well i can deal with that but when its in gear it does the same thing! which gets very confusing sometimes tryin to find gears and not to mention 5th gear is not just shifting up and over from 4th its more like shifting into neutral and then forcing it as far to the right as possible and then it goes in if u find the gear. it doesnt jump out of gear or anything like that its just with that much play in the shifter it becomes very hard and not fun for a daily driver. any help would be greatly appreciated thanx
Old 08-15-2005, 03:55 PM
blackcomet blackcomet is offline
Re: way too much play in shifter PLEASE HELP!
well al i know is that i have the stock shifter n wethers its in 1st gear or neutral it moves a couple insches on both sides..it is confusing at first but after a while you get used to it..as for a short throw..the side movements i think are suppose to be th same as stock..only front and back are obviously shorter
1993 Honda Civic CX HB--SOLD
1996 Honda Civic DX Coupe--SOLD
1995 Honda Accord EX 4dr--SOLD
1999 Honda Civic LX 4dr--proud owner (Bomz Racing CAI, OEM fogs, type R grill, eye-lids)
Hell yeah, mechanic at Honda and now part of the canadian armed forces!!
Old 08-15-2005, 08:08 PM
yeah i understand wut you are sayin but i have driven a few civics like mine and theyre actually pretty tight with little to no movement while in gear and i went ahead and installed the energy suspension bushing kit for the shifter but no help there either
Old 08-19-2005, 08:17 AM
got2bvtec got2bvtec is offline
if u go under ur car and check out the shift linkage ull find a little pin right b4 u get to the tranny, when u get a swap u have to take the pin out or its really aggravating. whoever did the swap probably didnt put the pin back in so they mightve used a bolt or a peice of wire, this makes the shifter really loose, check it out, make sure its not wire bc its might break going down the road and ull have even more probs, hope this help.
Old 08-21-2005, 05:01 PM
alright thanks ill check that out maybe thats the prob i sure hope so
