Old 08-15-2005, 01:00 PM
evilblue22 evilblue22 is offline
Trasmission Problem
Ive got a serious transmission problem. when my 91 Accord is in drive or any gear i hear a clicking sound while driving. when i put it in neutral and its coasting it clicks as well. however when i put it in neatral and push it dosent click wierd huh. can any one tel me what this is
Old 08-15-2005, 04:40 PM
mpumas mpumas is offline
Re: Trasmission Problem
And it is not CV joint problem?
Old 08-15-2005, 05:27 PM
Re: Re: Trasmission Problem
I dont know i did a search and most people say they have oil leakind on theyre tires. I dont have that but perhaps its that ill check it out thanks
Old 08-15-2005, 06:38 PM
Oil leaking on the tire is a damaged cv boot which will lead to a bad cv joint. However, you can get a damaged cv joint without the leaking. One way to tell is do turns. If it is a cv joint, the outside cv joint, if bad, will increase the clicking speed. It doesn't cost anything to do the test. Also look at the outside boots to see if they are cracked/broken. Maybe all the oil has long leaked out.
Old 08-16-2005, 08:30 AM
i did the turns the clicking stayed at the same speed it only increases with speed. are there berrings in the CV joint that could go bad or perhaps the splines that conect it to the hub or tranny
