Old 08-15-2005, 11:20 AM
blazin around blazin around is offline
Question electronic instrument panel dims ??
I have a 1994 LT Tahoe with the digital instrument panel, 4.3 L v-6 cpi. It didn't have a radio installed or the harness plug. I installed a sony cdx-m630 head unit using the factory wiring. When I turn on the park or headlights the panel dims. I contacted sony and they said to turn off the dimmer on the head unit, but this didn't work. This answer has to be simple because everything else works. please help...
Old 08-15-2005, 01:49 PM
ctesla's Avatar
ctesla ctesla is offline
I would first try taking an additional ground wire from the aftermarket unit and running it straight to ground.
if this doesn't help, I would re-route the power from the sony out of the factory wiring(thereby bypassing the original wiring (which probably powers the inst dash)), and take it straight to the hot in the fuse box.
I do have an original schematic for that model, if you want it emailed to you;
[email protected]
hope this helps,
chris
nrt racing
Old 08-15-2005, 05:32 PM
Re: electronic instrument panel dims ??
[email protected]
hope this helps,
chris
nrt racing
Chris, Thanks for the reply..I sent you my email address and alittle more info. Thanks again
