Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-15-2005, 09:31 AM
got80s got80s is offline
Send a message via AIM to got80s
battery or alternator?
This morning on the way to work at a red light my car just turned off. I had no power to anything. I couldn't turn on the emergency lights. So basically full power loss.
I have a dry cell battery on my car and I don't know too much about them. It's been on there for maybe 5 years. The connectors look good, no buildup and no connectivity issues from what I can see.
Once the car was towed back to the apartment the power came back on to the car and it would start. I don't know what would cause this other than an alternator that has gone bad.
Any hints ?
What a way to start a Monday...
"Sticking feathers up your butt does not make you a chicken"
http://www.somethingeasy.net
Old 08-15-2005, 11:53 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: battery or alternator?
Really stinks doesn't it!!! I would check all connections to the battery and the ground to the engine block. If your battery is 5 years old you need to replace it anyway since it has probably outlived its usefulness. Corroded or loose battery terminals or grounds can cause a problem like you indicated especially since there was no power whatsoever and the fact that it started later after being towed. So the connections would be where I would start.
Old 08-24-2005, 03:05 PM
maurycy maurycy is offline
I had the same problem (total loss of power) but even next day the car would not start. It was the battery. Replaced it and the car is working fine.
Old 08-27-2005, 12:09 AM
tomogchi tomogchi is offline
Send a message via AIM to tomogchi Send a message via MSN to tomogchi
.... I know this sounds completely out of the ball park, but could the bushings/bearings in the alternator be going? And when your car is running (at night) and you accelerate up a hill, does your headlights dim/brighten?
Much luck,
Bill
Old 08-30-2005, 07:36 PM
pheetus agungus pheetus agungus is offline
check the connection on the starter solenoid it may be hard to get at but most likely the cause. This has happened to me on more than a few cars.
