Old 08-15-2005, 08:02 AM
KLW45 KLW45 is offline
Code 43 Misfire
Can't shake this blasted code on my '96 3.3 Dodge Caravan. After changing plugs, plug wires, and coil pack the service light comes back on.
Old 08-15-2005, 11:49 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Code 43 Misfire
This could be an injector problem. You may need to replace the injector on the cylinder where you have the problem. Take the care to autozone and have them scan it with a scanner to really pinpoint which cylinder is misfiring. Once that has been done then swap out an injector from another cylinder and see if the code changes. If so replace the bad injector and the problem should be cured.
Old 08-19-2005, 06:02 PM
mmullas mmullas is offline
Re: Code 43 Misfire
I had the same problem on my '96 GC LE 3.8L. It turned out to be the upstream O2 sensor.
Old 01-01-2006, 10:10 PM
fishtones fishtones is offline
Re: Code 43 Misfire
I have code #43
No power, back fires. I can feather it up to highway speeds and it runs great
if I do not accelerate. Come to a hill or grade and it backfires
Hard to shift through all gears but it does get there. In neutral revving the engine causes a mis. Maybe only one or two cylinders. I have no diagnostic equipment. Now I think this:
Cam sensor
crank sensor
egr valve
bad plug or wire, would that backfire?
It idles so good and smooth
At steady speads on highway it runs good.
I put new exhaust system in so it's not plugged up, but it acts that way.
Code 43 say coil ignition primary problem
What is secondary ignition?
Scott
Old 01-02-2006, 09:37 AM
mld mld is offline
Re: Code 43 Misfire
had the same problem after rebuilding trany turned out to be the cam position sensor I had it pushed in too far pulled out a little and now it is running great. yours may be bad.
