Go Back   Automotive Forums Car Chat > Cars in General
Old 08-15-2005, 01:09 AM
Kicker F-150 Kicker F-150 is offline
Send a message via MSN to Kicker F-150
Flame Headliner
I know this has probably been posted before but I was wondering if anyone knew how to do this? I've seen it on Trucks and Horsepower TV a couple times but I forget to record them.
Thanx,
Ethan
Old 08-15-2005, 04:38 PM
hardcorejuggalo hardcorejuggalo is offline
Send a message via AIM to hardcorejuggalo
hmmmmm
this is easy if your good at interiors or had some type of practice. First thing you need is glue high temp glue. Second Sculpting foam to make the flames it comes in solid sheets so your draw your design out first cut it with a razor blade spray some glue down on your project lay the flame down in the best way you want it then spray more glue down on the cloth and the foam and project then press around flame and smooth out through out the whole headliner start in the middle.
My best suggestion is to try it on your speaker box first so if you screw it up you done have to spend all that time trying to fix your only headliner.
Its a Juggalo Thing MCL
