Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-14-2005, 10:19 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
problem installin sus. tech. sway bars.!
errr.. pissed/...
i was trying for a good 2 hr today trying to install the front sway bar. i removed the old one no problem.. the new 1 lined up ok or soo it seems.. no when i go to catch the u blots the nut attached to the frame attaches no problem but the on where you have to insert into the frame donest wana catch.. it looks like the red bushing is too thick!.. it not giving the bolt enough space to catch into to hole.. i
s this normal? do i have to shave down the bushing? or am i missing some thing?
currently i have no sway bars.. it sucks.. some on please help me.. have any of you experinced this problem?
and i didnt try the rear.. i have a le so their is no sway bar there.. i got the 4 bolts that i need to attach the u bracket.. any problemes that i should know about.. thanks
1
Shift_BOOST
97 s14
Old 08-14-2005, 11:36 PM
lost180 lost180 is offline
Re: problem installin sus. tech. sway bars.!
I had that same prob putting on my front SusTech sway bar!! I thought it was just me. lol
Basically I used an Impact, pushed really hard and squeezed... I think it even tried to cross thread, but the impact just drove through it.. hope I don't ever have to pull it off
rear went on noproblem.. jack up the suspension (to a resting level) makes it easier to do the connecting bolts on the ends..
(O=O/*180SX*\O=O)
Cops are just jealous of my big, fat di... um.... spoiler!
Old 08-15-2005, 09:10 AM
GSR2NR94's Avatar
GSR2NR94 GSR2NR94 is offline
Send a message via AIM to GSR2NR94
Yea the bushing is way too thick. I did the same thng and just cross threaded it with the impact, but to do it the right way, you might want to just trim down the bushing a little bit with a utility knife or something.
"Drifting is a passion, make love to a corner."
Old 08-15-2005, 12:45 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
You have to make the hole in the middle of the bushing bigger right? Would a Dremel work?
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 08-15-2005, 01:44 PM
TatII TatII is offline
i have no clue how mine fit perfect. hmmmm i guess i'm lucky.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 08-15-2005, 02:29 PM
orestes's Avatar
orestes orestes is offline
sounds like you are trying to line up the last bolt after the first two are already tightened up? try the reverse order. sometimes too you might have to jack up a part of the suspension with a floor jack to get it to line up. (or check that you arent already pushing up on something with where your jack is)
"I got that hustle in my genes like high blood pressure" -E-40
Old 08-15-2005, 03:25 PM
GSR2NR94's Avatar
Nah, I tried everything when installing mine. It was a bitch. I have heard on other forums that the bushing is too big also, and its true. Suspension techniques just makes the bushing too big. I now have energy suspension bushings in mine, and they went in a lot easier and fit perfectly how they should.
Old 08-18-2005, 06:49 PM
turbo2nr's Avatar
Re: Re: problem installin sus. tech. sway bars.!
thanks for all the feed back.. im gona try to shave down the bushings buts its a bitch when you dont have the propper tools.. if not ill just use the impact gun..
1
Shift_BOOST
97 s14
