Old 08-14-2005, 11:18 PM
JuiceAmixx JuiceAmixx is offline
Question Coils 4 & 1 spark 2 & 3 don,t
My 95 Talon Turbo the Coils 4 & 1 spark 2 & 3 don,t both coils are
getting power so I pulled out the coils and swithed the wires in the rear of the coils and 2 & 3 work but only with the wires from 4 & 1. The fuses are all good! Coil pack has been replaced! What could be the problem?
Old 08-14-2005, 11:29 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Very simple. Replace the coil pack.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-14-2005, 11:31 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Re: Coils 4 & 1 spark 2 & 3 don,t
My guess would be the wires are shot. Are they the stock wires? How many miles are on your car? I know mine flaked out around 130k miles but I think that is more a car/driver specific thing.
edit: I think I misread what you wrote. I agree with ^
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 08-15-2005, 03:54 AM
bl1tzk1213g bl1tzk1213g is offline
check the cam sensor. It happened to me once
1997 Mitsubishi Eclipse GS-T 5spd stock ?
Tsudo 3" catback
Bomz Intake
HKS SSQV BOV
bcs mod and a useless boost gauge
Old 08-15-2005, 05:40 PM
Thank you I missed that Ill let you know if it works!
Old 08-16-2005, 12:28 AM
ned032002's Avatar
ned032002 ned032002 is offline
Originally Posted by JuiceAmixx
My 95 Talon Turbo the Coils 4 & 1 spark 2 & 3 don,t both coils are getting power so I pulled out the coils and swithed the wires in the rear of the coils and 2 & 3 work but only with the wires from 4 & 1. The fuses are all good! Coil pack has been replaced! What could be the problem?
Well my first thought was change the coil pack but you said that you replaced the old one with another and the problem was still present. But...the only thing that I can think of is check the power feed for the coil pack and make sure that there aren't any areas that have been melted or maybe caught on something and pulled apart. Check the prongs in the wiring harness to see if maybe the prong may have been bent over... or maybe missing. Yeah maybe you just have a faulty wire like DragonofBC said. Good luck and welcome to AF, some advice add your car info into you sig makes things easier.
