Old 08-14-2005, 08:53 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
exhaust manifold
I'm getting to the point where I'm about to pick up a big ported 16g evo turbo and I've done alot of supporting mods, my exhaust is going to be on next week and my fuel pump probably about the same time. I was wondering after reading a few sites about exhaust manifolds. Some say that the 2g exhaust manifold flows pretty well and doesn't really need to be upgraded to much. should i shell out the extra bucks and buy a new better flowing ehxaust manifold to install with the new turbo or should the stock one be good enough?
Also what vac should the car sit at in idle? I'm not to experienced with checking for boost leaks and what not. mine sits at about 20 normally, sometimes a little bit lower. but usually about 20.
1991 GSX 2.3 Stroker
Old 08-14-2005, 08:58 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: exhaust manifold
The stock manifold will do fine. You really don't need it for a turbo. On a N/T car, it does have its bennefits. However with the turbo, even the larger ones, it won't make too much of a difference. If money is tight, don't do it. If you have plenty to spend, go for it. Again, not needed though. Good luck
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-14-2005, 09:10 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
It would like some porting though Just smooth it out a bit.
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-14-2005, 09:41 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
To answer your question about boost leaks, 20 vac is fine. Kevin mentions it here in his first reply:
http://www.automotiveforums.com/vbul...d.php?t=436825
Boost leaks make the vac closer to zero. I had a hole in the vac line going to my boost gauge and my car read 3 vac just for a related yet nearly pointless story .
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 08-14-2005, 09:55 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Stock Manny is fine. Port the 02 housing, or buy an Evo III 02 housing on ebay for $92 + Shipping
DSM geek
Old 08-14-2005, 10:33 PM
david-b's Avatar
Dave is THAT guy
Question about the porting the O2 housing... does that only work for turbo engines? On the N/T the o2 is on the dp, and it seems like it wouldnt make a difference. Correct?
75 Monte Carlo
Old 08-14-2005, 11:48 PM
defiancy's Avatar
yep I bought a ported o2 housing from ebay. actually only cost me 74 dollars it's ported out to 3 in or so I think.
