Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-14-2005, 06:17 PM
larryscope larryscope is offline
Dirty A/C Evaporator
Does anyone have any recommendations for how to clean a dirty A/C evaporator on a '92 Olds 88? We removed the blower & motor and were able to stick a household vacuum cleaner into the blower module and pick up some of the dirt. The airflow from the A/C vents seems to have increased significantly.
Is there a way to remove the blower module and expose the evaporator completely without having to bleed off the freon and remove the accumulator?
Old 08-14-2005, 09:27 PM
Jim Adams Jim Adams is offline
Re: Dirty A/C Evaporator
you should probably just blow it out real good with high pressure air and do as you are doing ,,sucking it out with a vaccuum,,its not gonna come out unless you evac the system.Good Luck
