Old 08-14-2005, 06:52 PM
tinknocker tinknocker is offline
stuck tailgate
went to open tailgate yesterday and it was stuck shut! one side seems to be releasing but other side is stuck. anybody else have this problem, if so how did you fix it?
Old 08-14-2005, 07:18 PM
greenz71 greenz71 is offline
sounds like the tailgate handle broke inside the tail gate and only pullin one side alose look between the handle and the cover around it and see if both sides move when you pull up
2000 z71 escb k&n fipk tb spacer hyper tech programmer flowmaster exhaust flex-a-lite fans 3in body lift cranked torsion bars with ford keys super lift aal rancho 9000x shocks with in cab adjustment
315-75/16procomp mt
82 cj7 4in super lift springs with spring over up front 6in super lift spring in the back 36x12.50-15 super swamper tsl
94 mazda b2300 stock as you can get (gas saver)
if it wont go i dont need it
Old 08-14-2005, 08:26 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: stuck tailgate
Take off the plastic thing around the tailgate handle. Be careful, it will brak easily. Its only 7$ at a dealer.
Anyhow, when you get this off, you can see the two rods that unlatch the tailgate. One of them has probably come loose from the handle and is not releasing. THe little plastic retainer clip that holds it in could possible be broken. This is what was wrong with mine. After buying the replacement clip and the tailgate handle surround, it cost me a total of about 7.50.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-16-2005, 08:30 PM
Re: stuck tailgate
hey, thanks you were right that little plastic chingedero was broken that holds the rod in place.
Old 08-21-2005, 02:14 PM
JimIam JimIam is offline
Re: Re: stuck tailgate
Thanks for posting that info...Mine had the same problem.
Old 08-21-2005, 03:07 PM
jeverett's Avatar
Re: stuck tailgate
Sure dude, anytime.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-22-2005, 10:52 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i think this is a common problem with alot of trucks, they use plastic clips to pull metal parts and they cant handle it. atleast it is easy to get to on these trucks to fix and cheap.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 08-22-2005, 11:46 AM
jeverett's Avatar
Re: stuck tailgate
Yeah. When mine broke I wasnt sure what it was, and I was sitting in the bed, kicking the tailgate while my friend tried to open it. After I found out what it was and how easy to fix, I felt kind of stupid
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-19-2005, 11:44 PM
petes97 petes97 is offline
Anyone have the part number for the clips? My dealer says they don't come by themselves. The jerks are telling me I have to buy a new assembly for $42
Thanks,
Pete
Old 10-20-2005, 07:49 AM
VA2500HD VA2500HD is offline
Re: stuck tailgate
You don't need to get the clips from a dealer. Go to an auto parts store and get a variety pack of clips, not more than a dollar or two. Be careful if you have a spray in liner. The 3 tailgate handle bolts on the inside of the tailgate must be backed out or you'll crack the clips for the oval shaped cover that goes around the handle. I cracked 3 of them at $22/piece before figuring it out.
Old 10-20-2005, 08:08 AM
jeverett's Avatar
yeah, I learned the hard way too.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-21-2005, 07:47 PM
Re: stuck tailgate
I took my broken clip to the local Napa auto parts store and found one for $1.25. I also cracked off one of the tabs that go on the plastic piece that goes around the handle. I fixed that with some J.B. Weld. I got off pretty cheap on that deal.
