Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 08-14-2005, 05:10 PM
IndyMac IndyMac is offline
Instrument panel 1997 question....
Where can I find a description of all the warning lights on my intrument panel? (hopefully on the web somewhere.) 1997 Sunfire, SE.
Old 08-15-2005, 11:05 PM
SirCull SirCull is offline
Send a message via MSN to SirCull
Re: Instrument panel 1997 question....
Should be in the owners manual....otherwise just use your best judgment...they are usually pretty ovbious
What are you having trouble with?
Thanks SiZZY for the Sig
Old 08-16-2005, 09:25 PM
Re: Re: Instrument panel 1997 question....
I don't have the owners manual and the repair book I have doesn't descibe, or even show, the symbols.
I just want to know what they mean before something goes wrong.
Old 08-17-2005, 01:12 PM
King Of Crunk's Avatar
King Of Crunk King Of Crunk is offline
WTF are you talking about? the lights are shiny and bright....and work better at night.....details M-F'r...sheesh
DO IT REAL BIG CREW #1
THE OLD DIRTY BASTARDS CREW #5
2004 Honda CBR 1000RR - It Gets The Ladies
2004 Caddilac Escalade - Brings 'Em Home
Old 08-17-2005, 02:39 PM
matt09524 matt09524 is offline
Send a message via MSN to matt09524
Ok well, I think the above response is a bit harsh, but here goes...
CHECK with a picture of engine above - something non-fatal is wrong
AIR BAG - Your Air Bag system is likely not working.
ETS OFF - Traction Control system is off (the button on the shifter is not on)
Red oil can - Stop and put oil in your car immediately then find out why the light came on. You have a leak or you have not changed the oil in like 30k miles or something.
ABS - Something is wrong with your anti-lock brakes
(Three squiggly vertical lines) - over heating, loss of coolant.
ANTI THEFT - if installed, something wrong with it or it is on (whether it should be or not)
Headlight looking thing - day time running lights on (turns off when headlights are on)
Seat belt (obvious picture) - Your seat belt is not on, or the switch in the drivers buckle is broke.
There are probably a couple more that im nto thinking of, those are the common ones.
Old 08-17-2005, 06:57 PM
The one that is on looks like a square, with what I'm assuming is a line that looks like water, with an arrow above the box pointing down. My guess is that it means, low water level or some sensor has gone bad. Thanks for the help.
Old 08-18-2005, 02:25 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
check your coolant, IIRC that's the low coolant warning, look at the tank, and if it's to proper level, then the sensor is bad.
Old 08-18-2005, 02:30 AM
hazzzmattt hazzzmattt is offline
im guessing you havent owned to many cars yet but your gonna. best thing to do is buy an owners manual. you can get almost any of them on e-bay for a buck or two
Old 08-18-2005, 02:34 AM
and..." a little harsh" is the understatement of the week. give the kid a break for god sake. you gotta get the answers to questions somewhere.
Old 08-18-2005, 11:49 AM
hotbug1776's Avatar
He's just jealous that his car can be beat by a few of us on here LOL. Some people dont realize that all car owners are not ASE certified, and they only want some info to not have to visit the dealer and pay high prices.
Old 08-18-2005, 12:31 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
By the description above, my first guess was low fuel indicator.
Isn't the symbol for coolant the International water bucket with a spout?
(My Chrysler has a similar indicator for fuel, a box with a hose and wavy lines)
So much for the International visual displays instead of writing, what do blind people use - afterall, the local ATM machine I use has braille symbols on the drive-thru machine..... Blind drivers, not a good thing.
Old 08-18-2005, 02:42 PM
On a lot of cars from atleats 97 up, "CHECK GAUGES" means your fuel is low. That light you described is indeed the coolant system. I was wrong about the 3 vertical squiggly lines. hehe Check your radiator for leaks, as wells as your lines to and from and your resevoir.
